Solved
ML Hub: Deployed Successful but not shown in ML Tag
  • Feb 12, 2026 10:48 AM UTC
  • 5 replies
  • 104 views
Dear All
I’ve already deployed the pmml in MLHub but when its success. There’re no ML Tag for creation in Trendview. Does anyone found same problem?
Best answer by fvandael
Hi ​@Thanawath.Ruangsamuth,
Could you please run the code snippet bellow in an MLHub Notebook this should list all available PMML models that you have.
This way I can confirm the publishing was correct.
Kind regards,
Frederik
from trendminer.trendminer_client import TrendMinerClient
from trendminer.ml.models import ZementisModels
import os
token = os.environ["KERNEL_USER_TOKEN"]
# Create TrendMiner API object
client = TrendMinerClient(token)
models = ZementisModels(client)
all_models = models.list_models()
print(all_models)
View original
Jef Vanlaer
Community Manager
  • Community Manager
  • Feb 12, 2026 10:50 AM UTC
Once you have successfully deployed the model, you should set up your Machine Learning Model tag through the Tag Builder as a next step, as described here: https://userguide.trendminer.com/en/tag-builder--machine-learning-model-tag.html
Let me know if that solves your question…
Kind regards,
Jef
Kind regards,
Jef
Thanks for the reply. It not shown any pmml model to chose for Builder. IDK why but it shown success in my code without errors.
  • Employee
  • Answer
  • Feb 12, 2026 11:11 AM UTC
Kind regards,
Frederik
import os
print(all_models)
Kind regards,
Frederik
import os
print(all_models)
Here’s the output
[]Please see my deployed code below.
# 3. SECURE PMML EXPORT
from datetime import datetime
from nyoka import skl_to_pmml
timestamp = datetime.now().strftime('%Y%m%d_%H%M')
model_name = f"PDP_10Min_Forecast_{timestamp}"
pmml_path = "pdp_10min_forecast.pmml"
# Export trained pipeline to PMML
skl_to_pmml(
pipeline, # your trained Pipeline
feature_cols, # list of feature column names
'Future_PDP', # target column name
pmml_path,
model_name=model_name
print("PMML exported successfully:", pmml_path)
# 4. DEPLOYMENT WITH ERROR HANDLING
try:
z_models = ZementisModels(client)
with open(pmml_path, "r") as f:
pmml_content = f.read()
model_id = z_models.deploy_model(pmml_content)
print(f"\n✅ SUCCESS! Model Deployed.")
print(f"Model ID: {model_id}")
except Exception as e:
print(f"\n❌ Deployment failed.")
print(f"Technical detail: {e}")
  • Employee
  • Feb 17, 2026 8:25 AM UTC
Hi @Thanawath.Ruangsamuth,
If I understand correctly, you were able to deploy your model successfully and your code outputs the model_id.
If the model_id is printed, the all_models list should also contain the models.
Could you please confirm whether the model_id is being printed?
Kind regards,
Frederik
