Which API calls are useful to monitor datasource health?
  • Jun 3, 2025 2:41 PM UTC
  • 2 replies
  • 189 views
Ensuring your datasources are consistently available and performing optimally is key to maintaining a healthy TrendMiner environment. Fortunately, the Connector API provides several endpoints that can help automate health monitoring for your datasources. Below, we explain how you can leverage these API calls to detect connection issues and performance degradation — even with a simple script.
Accessing connector API:
https://documentation.trendminer.com/en/using-the-connector-api.html
Checking if Datasources Are Available
To determine if a datasource is down (showing red status in the UI), use the following two-step process:
  1. Retrieve all datasource IDs
    Call: GET /database
    This returns a list of configured datasources with their IDs.
  2. Test each datasource connection
    For each ID from step 1, call:
    GET /database/{id}/test
    This will return whether the datasource is currently healthy or not (basic connectivity check).
You can automate this process with a script that runs these calls regularly and alerts you if any datasource is down.
Monitoring Datasource Performance Metrics
In addition to basic connectivity, the Connector API also offers performance-related metrics that provide deeper insight into datasource health:
  • Retrieve all datasource IDs
    Call: GET /database
  • Call to retrieve metrics
    GET /database/{id}/metrics
  • Example JSON response:
"DatabaseIndex50pInMillis": 5,
"DatabaseIndex95pInMillis": 7,
"DatabasePlot50pInMillis": null,
"DatabasePlot95pInMillis": null,
"DatabaseSync50pInMillis": 316,
"DatabaseSync95pInMillis": 357
These values show the latency (in milliseconds) for different types of operations:
  • Indexing
  • Plotting
  • Synchronization
These metrics measure the time from the connector to the datasource, not the full path to TrendMiner.
Shams92
Polestar
Forum|alt.badge.img+3
  • Polestar
  • Jun 6, 2025 12:04 PM UTC
Interesting topic! I imagine this would open up similar performance monitors as you can configure for servers and interfaces in the PI System. These monitors help us a lot to improve the performance of the PI System.
Jef Vanlaer
Community Manager
  • Community Manager
  • Jun 6, 2025 1:22 PM UTC
​@Shams92 If you want to have a quick look at the data source metrics on your current setup, they are available in ConfigHub as well. Check this documentation for more information on how to interpret them: https://documentation.trendminer.com/en/how-to-evaluate-time-series-data-source-metrics.html
