Discover our learning resources and share your experiences...
Recently active
New to TrendMiner? Ready to start analyzing your process data more easily and faster than ever before? Here's a learning path to quickly reach first value with our platform and to gradually build your TrendMiner knowledge and ability: In-App Onboarding FlowUpon your first login, you can follow the in-app onboarding flow. This guided process is designed to familiarize you quickly with our platform's functionalities and capabilities which will improve your work flow. If you prefer, you can access the in-app guides at any time via the Help Center.Onboarding EmailsYou'll receive a series of onboarding emails that contain valuable information and tips to help you start your journey with TrendMiner. However, please note that your company might have disabled these resources, so ensure to check with your admin if you don't receive them.Walk through the TrendMiner Basic GuidesThe bite sized short Basic Guides videos help you understand how to use TrendMiner in your daily work by focussing on pr
Recordings of our recent advanced trainings are available via the following Vimeo playlists:English GermanHere's an overview of the available recordings:Take Your Dashboards Further: What's New in DashHub [English, German] Beyond Value-Based Search: Counting Events with Formulas in TrendMiner [German, English] Define, Compare, Improve: Golden Batch Profiling in TrendMiner [English, German] From Data Points to Decisions: Advanced Scatter Plot Analysis [English, German] Event Analytics in Action: Gain Deeper Process Insight [English, German] Daily Production & Automatic Reporting [English, German] Data Preprocessing: Preparing Your Data for Comparable Analysis [English, German] DashHub – Create a Control Center of your Process [English, German] Statistical Reporting Tricks: Track the Danger of Climate Change [English, German] Mastering Tag Types in TrendMiner – Tips, Tricks & Hands-On Exercises [English, German] Value Based Searches – Tips & Tricks [English, Germ
Here’s a handy way to use the TrendMiner AI agent: instead of opening each monitor one by one, ask it to review all of them at once and build you a weekly digest. With one short prompt, it ranks which monitors need attention, shows the assets and conditions behind each one, spots patterns like escalating trends or night-only alarms, and tells you where to look first. You’ll get the same results whether you use the in-app TrendMiner agent or an external AI tool connected to TrendMiner. Try it yourself. You can simply copy the prompt below.Can you look at all my TrendMiner monitors for last week and put together a weekly digest? I want to know which ones need attention, what patterns you see, how they relate to each other, and what I should look at first. Include the components, assets and conditions for each monitor too.
SABIC is one of the world’s largest chemical companies. It celebrates its 50th anniversary this year and has grown to around 26,000 employees and about 60 manufacturing and compounding sites. At TrendLab 2026, Maurice and Christoph from SABIC shared their approach to smart plant monitoring. Their general message was technology alone is not enough. Successful monitoring needs people who understand its value and are properly trained, a clear process with an owner for every monitor, and the right platform for data integration, analytics and visualization. That’s why SABIC chose TrendMiner. Use case 1: Evaluating new technology in the crackerThe coils in SABIC’s cracker furnaces slowly build up coke on the inside, which raises their temperature until they must be cleaned. SABIC wanted to know whether a new technology really reduced this buildup. Using TrendMiner, the team identified every operating run, built fingerprints of the runs before and after the change, and compared them. The
The TrendMiner AI works with your process data whether you open the TrendMiner Agent right inside TrendMiner or use your company’s AI assistant, such as Copilot, ChatGPT or Claude, through the TrendMiner MCP server. It can search for events, run calculations and show you the result in TrendHub. How useful the answer is depends mostly on how clearly you ask, and a few simple habits make a big difference. Write your prompt for a colleague on their first dayThink of the AI as a very capable colleague on their first day at your site. They understand process engineering and know every corner of TrendMiner, but they have no idea which tags belong to which unit, what your operating limits are or what you’re actually trying to find out. Anything you would tell that colleague before they start, tell the AI. The six ingredients of a good promptContext: which unit, and what question you’re trying to answer, e.g. “low yield on the last three batches in reactor R1” Exact tags: the full tag name as
Most plants run more monitors than anyone can review in a week. Across three sites, that can easily mean 400 monitors and well over a thousand triggers.With our TrendMiner MCP integration, an AI assistant can already read your monitors and their trigger history directly. That makes work that is close to impossible by hand a routine task:A weekly report of every monitor that fired, across all your sites A ranking of what to look at first, based on how often a monitor fired, its trend and how critical the asset is A list of noisy monitors that fire constantly and probably need retuningThe AI agent does the scanning, and your engineers decide what to act on.
Walking up to a pump, a reactor or a filler line and having its live dashboard on your phone in seconds is now easy. TrendMiner can generate a QR code for any dashboard. Stick it on the equipment, scan it with your phone, and the dashboard opens in mobile mode.Step 1: Create the QR codeOpen the dashboard in DashHub. Click Actions in the top right and choose Share.Dashboard actions menu with Share highlighted In the Share window, click the QR code icon in the bottom left corner.Share window with the “Create QR code” icon Your QR code appears. Click Download to save it as an image you can print, laminate or add to a label.Generated QR code with Download button Before you print, check two things. First, make sure the people who will scan the code have access to the dashboard. You can invite them from the same Share window. Second, set a sensible default time frame on the dashboard, because that is what opens when someone scans it.Step 2: Scan it in the fieldOpen TrendMiner in your phone’s
Hello 👋One of the things we value most in this Community is how much you learn from each other. So when Monument Chemical published an article on their website about how they use TrendMiner and AI, we wanted to share it here as a use case for all of you.The challengeManufacturing specialty chemicals creates huge amounts of data: temperatures, flow rates, lab results, tank inventories. The value sits in connecting those sources and analyzing them quickly, but gathering and analyzing it used to take hours.The approachMonument’s engineers use TrendMiner to bring data from multiple sources into one platform. Instead of spending hours gathering and analyzing data, the engineers can quickly compare production runs, spot patterns, identify potential issues, and find opportunities to improve.The results at their Houston siteAbout 60% less time from catalyst activation to a shippable tank A higher-purity product for a customer, found in years of historical data, without significantly longer p
Hello 👋,The recording of the webinar “What's New in TrendMiner 2026.R3.0? “ is now available.Watch the recording: SlidesRelease NotesYour idea could be nextIn this release, logarithmic scale went from a request on our Ideas page to a functionality you can use today. Our product team reviews every requests regularly, and the most supported ideas help decide what we build next.Have a feature request? Submit it at https://community.trendminer.com/ideas and vote on the ideas that matter to your team.
Hello 👋Here's a short recap of some of the customer sessions at TrendLab 2026 in Houston. The presentation slides are attached for a closer look.Monument Chemical integrated tank inventory and lab data into TrendMiner. Layer comparisons showed that most of an unwanted impurity came at the start of distillation runs, so a higher-purity customer request was met with only slightly more column time. Comparing catalyst activation runs helped cut the time to the first on-spec tank from 21 days to 8.👉 Check the slides here.Martin Marietta rolled out TrendMiner across network-segregated sites with hands-on training. On its kilns, filtering isolates burning cycles for fair comparisons, and similarity search plus diagnosis traced secondary air temperature spikes to their root cause, reducing temperature variability by 27%. Monitors now send downtime alerts to the right teams automatically.👉 Check the slides here: Presentation 1 & Presentation 2Huntsman built soft sensors from drum level
The AI Use Case LadderIntroduction We have shown this use case framework a few times now, as a useful way to get people thinking about their own use cases and structure their AI projects. Due to popular demand, I’m sharing it more widely here on our Community as well so all our customers can potentially benefit.The idea behind the framework is relatively easy: start small, experience success, and build from there. Why trust matters The question it always provokes is the obvious one. Level 5 holds great promise: standardised, corporate, enterprise-scale value, visible all the way up to management reporting. So why not start there?Because the steps in between deliver value too, and skipping them means skipping what makes the higher level use cases sustainable. Each level earns its own return, and along the way it builds the trust, momentum, and muscle memory you need to climb higher.Let’s start with trust.Trust comes by foot and leaves by horse. It builds slowly, question by question, an
Hello 👋Here's a short recap of some of the customer sessions at TrendLab 2026 in Eindhoven. The presentation slides are attached for a closer look. SABIC shared three use cases from Geleen. Fingerprints on multi-year furnace data made coil coking trials faster and more reliable to evaluate. A multivariate model in TrendHub predicted bearing temperature on 4 assets, so a repair could move to a planned stop just in time, preventing more than €1M in losses. A regression model helped find a "golden recipe" for a hard-to-control grade, which has been 100% within spec since and adds over €500k gross margin per year. Next step: scaling to the full Geleen site. 👉 Check the slides here. AVR grew from 50 to 120 users across its two waste-to-energy sites, 70% of them in production. MES, LIMS and emissions data now sit next to historian data, control room dashboards are maintained by operators 24/7, and three historians were merged into one with over 150 views migrated.👉 Check the slides here.
Hi! 👋The recording of our September 2026 live training Take Your Dashboards Further: What's New in DashHub is now available! 🎉In this session, we walked you through the latest DashHub updates: monitor key values with the new gauge tile, display trend statistics right on your dashboard with the new statistics table view, and further customize your dashboard to fit your needs.Recordings:German EnglishSlides:German English
Hello 👋In this session, we covered the different ways TrendMiner integrates with data sources, from the supported providers to custom connections and other integration methods, and we looked at the latest and upcoming ODBC improvements. You can find the slides here. Watch the recording here 👇
Condition-based maintenance 🔧 is powerful. Monitor what's happening and act only when needed. But some maintenance tasks still need to track time 🕑. Regulatory requirements don't care if your asset is running smoothly. Some failure modes are unpredictable and preventive by nature. And if your equipment runs 2 hours in winter and 18 in summer, a calendar-based schedule is useless. You need to track actual operating hours since the last maintenance event.The strongest programs use both. You monitor bearing temperature and oil quality in real time. You also ensure critical seals get replaced every 5,000 operating hours. With TrendMiner's custom calculation feature, you can build a time-since-maintenance tag by defining the operating conditions that "count" toward your interval, then tallying the actual hours. Set a monitor and get alerted when you hit the threshold. When the equipment has actually earned the maintenance.Want to build operating-hour counters for your equipment? Reach out
Hello 👋,The recording of the webinar “What's New in TrendMiner 2026.R2.0? “ is now available.Watch the recording: Release Notes SlidesHere is the summary of the webinar: Mobile Dashboards: Your TrendMiner insights are now on your phone, with no app to install, so they travel with you on the plant floor, on a walkround, or away from the control room. You can even scan a QR code on a piece of equipment to open the right dashboard in seconds.Increased Level of Nesting for Calculated Tags:Calculated tags can now be nested up to 20 levels deep, so you can build hierarchical roll-ups that mirror your plant: compute KPIs at unit level, aggregate at area level, and roll them up to plant level, with each step saved as its own reusable tag. The tag dependency browser also gains an Edit button that takes you straight to the Tag Builder.TrendMiner's New MCP Server:It connects your process data and analytic tools to the AI assistant your team already uses. Engineers and operators can ask question
Weather and climate conditions have a measurable impact on manufacturing operations. Temperature fluctuations affect material properties, humidity influences product quality, and atmospheric pressure can impact equipment performance. By bringing weather data directly into TrendMiner, you can correlate these environmental factors with your production metrics in real time, revealing patterns that spreadsheet-based analysis misses.Quick exampleHere's a Python script you can run within custom calculations to extract the latest weather data and create a new tag with it. You can also create your own custom connector using our API documentation; reach out to your Customer Success Manager or the TrendMiner Support Team for more information.import pandas as pdfrom datetime import datetimeimport pytzimport osimport requestsfrom trendminer import TrendMinerClientclient = TrendMinerClient.from_token(token=os.environ['ACCESS_TOKEN'])output_file = os.environ["OUTPUT_FILE"]# Set your facility timezon
Do you have spaced events such as batches, equipment startups or production runs of a particular product type that you want to visualize side by side? Apply a manual filter or a search-based filter that captures the timeframes between each event, then collapse the filters. You can now see these events stitched next to each other for a clearer view of each.
Hello 🖐🏻By combining TrendMiner's existing functionalities and using automation, you can build more complex solutions for a wide range of operational challenges.During this session, we demonstrated what's possible through three real-life examples:• Overall Equipment Effectiveness (OEE) reporting• Energy management• Golden Batch monitoring SlidesRecording: Need a solution built in TrendMiner? Want to enable your team or yourself to build your own solution in TrendMiner?Reach out to us!
New to TrendMiner or five years in, this cheat sheet keeps the platform's core capabilities one page away. It follows the natural path of an analysis, from descriptive and diagnostic through to predictive, then covers the knowledge management and dashboarding features.
Hi! 👋The recording of our July 2026 live training Beyond Value-Based Search: Counting Events with Formulas in TrendMiner is now available! 🎉In this webinar you can learn formula-based techniques to count and analyze events beyond a simple value-based search. You can also discover how to count events from the focus chart with Formula tags, determine how often an event occurs within another event, and break down event counts by month. Recordings:German EnglishSlides:German English
Gantt charts give morning meetings a clear starting point. Every asset, its operational state, and any events from the last shift are laid out on one timeline, so teams can quickly see what happened overnight, agree on which anomalies are worth digging into, and move into investigation without spending the first 15 minutes piecing the story together from trends.A few practical applications we've seen work well:Instant "did we run?" answer. Green operational bars show uptime coverage at a glance, and any gaps immediately draw the eye. Batch cycle flags. Conditional formatting turns any batch red when cycle time, temperature, or quality exceeds threshold, so the meeting starts with the exceptions rather than the routine. Planned vs. unplanned at a glance. SAP or CMMS maintenance events sit inline with process upsets, removing the "was this us or them?" debate. One-click drill-down. Click any bar to open the context item and jump into TrendHub with tags and timeframe pre-loaded, moving fr
Yesterday, Christina Linne (Head of Product Marketing) and Tim Haselaars (Product Manager) hosted a webinar introducing the TrendMiner Agent, our native in-application AI capability. If you missed it or want to revisit it, the recording is available below. What's covered The session walks through what the TrendMiner Agent is, how it's built, and what it looks like in practice:The foundation: how the agent combines an LLM of your choice, TrendMiner's analytics tools, and your historian data into a single, orchestrated experience native to the TrendMiner interface Agent skills vs. agent tools: why giving an AI access to your data isn't enough, and how process engineering expertise is encoded into the agent's reasoning Live demo: a combined cycle gas turbine use case, from a rising heat rate anomaly through root cause analysis to economic impact quantification Routines: the companion feature that turns a one-time agentic analysis into a repeatable, structured workflow How this differs fro
Hello 👋In this session, we covered the different types of administrators in TrendMiner and what each one can do, the identity providers you can connect to manage authentication, and how user roles determine what people see and can act on. You can find the slides here. Watch the recording here 👇https://vimeo.com/1202174203?share=copy&fl=sv&fe=ci
Hello 🖐In Part 1, we got to know Yves and looked back on his journey with TrendMiner and our Community. Yves is Director Technology at Valero Energy, the largest independent refiner in America, based at their San Antonio headquarters. He’s responsible for some key applications related to Process Key Performance Indicators (KPI) monitoring, engineering documentation management and analytics with TrendMiner.Now let's look together at the lesson Yves believes every process expert should know and his advice for the next generation.Your LegacyWhat’s the achievement or moment you’re most proud of in your career?My unique background allowed me to be at the service of others, like Process SMEs, and I am proud that my work helps them with their day-to-day work and make them shine.What’s the most valuable lesson you’ve learned that you’d say “every process expert should know this”?This may sound odd, but I believe that there is a very high value in documenting your work and sharing knowledge.
Already have an account? Login
