Get tips, insights, and strategies to achieve your goals
Recently active
Here’s a handy way to use the TrendMiner AI agent: instead of opening each monitor one by one, ask it to review all of them at once and build you a weekly digest. With one short prompt, it ranks which monitors need attention, shows the assets and conditions behind each one, spots patterns like escalating trends or night-only alarms, and tells you where to look first. You’ll get the same results whether you use the in-app TrendMiner agent or an external AI tool connected to TrendMiner. Try it yourself. You can simply copy the prompt below.Can you look at all my TrendMiner monitors for last week and put together a weekly digest? I want to know which ones need attention, what patterns you see, how they relate to each other, and what I should look at first. Include the components, assets and conditions for each monitor too.
SABIC is one of the world’s largest chemical companies. It celebrates its 50th anniversary this year and has grown to around 26,000 employees and about 60 manufacturing and compounding sites. At TrendLab 2026, Maurice and Christoph from SABIC shared their approach to smart plant monitoring. Their general message was technology alone is not enough. Successful monitoring needs people who understand its value and are properly trained, a clear process with an owner for every monitor, and the right platform for data integration, analytics and visualization. That’s why SABIC chose TrendMiner. Use case 1: Evaluating new technology in the crackerThe coils in SABIC’s cracker furnaces slowly build up coke on the inside, which raises their temperature until they must be cleaned. SABIC wanted to know whether a new technology really reduced this buildup. Using TrendMiner, the team identified every operating run, built fingerprints of the runs before and after the change, and compared them. The
Hello 👋Here's a short recap of some of the customer sessions at TrendLab 2026 in Houston. The presentation slides are attached for a closer look.Monument Chemical integrated tank inventory and lab data into TrendMiner. Layer comparisons showed that most of an unwanted impurity came at the start of distillation runs, so a higher-purity customer request was met with only slightly more column time. Comparing catalyst activation runs helped cut the time to the first on-spec tank from 21 days to 8.👉 Check the slides here.Martin Marietta rolled out TrendMiner across network-segregated sites with hands-on training. On its kilns, filtering isolates burning cycles for fair comparisons, and similarity search plus diagnosis traced secondary air temperature spikes to their root cause, reducing temperature variability by 27%. Monitors now send downtime alerts to the right teams automatically.👉 Check the slides here: Presentation 1 & Presentation 2Huntsman built soft sensors from drum level
The AI Use Case LadderIntroduction We have shown this use case framework a few times now, as a useful way to get people thinking about their own use cases and structure their AI projects. Due to popular demand, I’m sharing it more widely here on our Community as well so all our customers can potentially benefit.The idea behind the framework is relatively easy: start small, experience success, and build from there. Why trust matters The question it always provokes is the obvious one. Level 5 holds great promise: standardised, corporate, enterprise-scale value, visible all the way up to management reporting. So why not start there?Because the steps in between deliver value too, and skipping them means skipping what makes the higher level use cases sustainable. Each level earns its own return, and along the way it builds the trust, momentum, and muscle memory you need to climb higher.Let’s start with trust.Trust comes by foot and leaves by horse. It builds slowly, question by question, an
Hello 👋Here's a short recap of some of the customer sessions at TrendLab 2026 in Eindhoven. The presentation slides are attached for a closer look. SABIC shared three use cases from Geleen. Fingerprints on multi-year furnace data made coil coking trials faster and more reliable to evaluate. A multivariate model in TrendHub predicted bearing temperature on 4 assets, so a repair could move to a planned stop just in time, preventing more than €1M in losses. A regression model helped find a "golden recipe" for a hard-to-control grade, which has been 100% within spec since and adds over €500k gross margin per year. Next step: scaling to the full Geleen site. 👉 Check the slides here. AVR grew from 50 to 120 users across its two waste-to-energy sites, 70% of them in production. MES, LIMS and emissions data now sit next to historian data, control room dashboards are maintained by operators 24/7, and three historians were merged into one with over 150 views migrated.👉 Check the slides here.
Hello 🖐In Part 1, we got to know Yves and looked back on his journey with TrendMiner and our Community. Yves is Director Technology at Valero Energy, the largest independent refiner in America, based at their San Antonio headquarters. He’s responsible for some key applications related to Process Key Performance Indicators (KPI) monitoring, engineering documentation management and analytics with TrendMiner.Now let's look together at the lesson Yves believes every process expert should know and his advice for the next generation.Your LegacyWhat’s the achievement or moment you’re most proud of in your career?My unique background allowed me to be at the service of others, like Process SMEs, and I am proud that my work helps them with their day-to-day work and make them shine.What’s the most valuable lesson you’ve learned that you’d say “every process expert should know this”?This may sound odd, but I believe that there is a very high value in documenting your work and sharing knowledge.
Hello 👋 We want to take a moment to recognize one of our most valued Community members: Yves Racette, who has reached Polestar🌟, the highest rank in our Community. 🎉 Yves is Director Technology at Valero Energy, the largest independent refiner in America, based at their San Antonio headquarters. He’s responsible for some key applications related to Process Key Performance Indicators (KPI) monitoring, engineering documentation management and analytics with TrendMiner.As Yves prepares to retire, we did an interview with him to capture his journey, the lessons he’s learned over a full career as a process expert, and his advice for the rest of us. Let’s Get to Know YouCan you tell us about your background?I graduated as a Chemical Engineer from Laval University in Quebec City, Canada. I had an unusual career for a Chemical Engineer as I worked in Automation, with Data Historian systems and in software development during my entire career.What’s your role day to day? I typically manage u
"How do I prove the ROI of TrendMiner?"The value is usually there. But it lives in people's heads, in emails or in reports that have gone lost in Sharepoint. When the business asks for proof, you end up reconstructing instead of reporting.In the latest Success Series webinar for Strategic stakeholders, our CSM Lead @Tommy Peters presented a framework to capture value continuously. It's a lightweight system with three layers, explained below… Curious to see the full webinar? Check it out here: Layer 1: Capture at the moment of workWhen an engineer finishes a meaningful piece of analysis, they report four things right then:What problem it addresses How big it is roughly Who should validate it When it was completed.Don’t ask them to make a full ROI calculation, just capture enough context to build on later.Give the size scale some shape (e.g., Large means it affects a full production line or represents an estimated annual impact of €50,000 or more). Use whatever you already have: a field
Hello,Our third TrendMiner Success Series Strategy webinar's recording is now available! In this session, we walked through the three stages of value maturity we see across our customer base, the behavioural reasons most programs stall in stage one, and a three-layer approach you can start applying next week to catch value at the moment it happens, harvest it as a team, and build a portfolio your sponsor can defend.Watch the recording:
Here’s a question that pops up regularly in customer meetings, usually 2 to 3 years in:"What value are we actually getting from TrendMiner?"It's a fair question. And it almost always leads to a second one that's harder to answer:"What value were we hoping to achieve?"When nobody has a clean answer to that second question, people start listing anecdotes, pulling up usage numbers, trying to build a case on the fly. It feels defensive rather than confident. Even when the results are real… The fix is actually simple: a one-line vision. One sentence, written before the program gets started (or now if you don’t have one yet), that answers: what are we trying to achieve, for whom, by when. Bayer called it: "Uncover hidden potential to initiate process improvements directly on site." Ten words that gave the program lead a filter for every use case decision and the sponsor something concrete to fund and protect.From there, the use cases selected themselves. A root cause analysis of viscosity pr
After 10+ years of seeing TrendMiner implementations succeed (and sometimes not), one thing stands out: our most successful customers share the same characteristics. That observation, combined with change management principles, is what led us to build the TrendMiner Success Framework.You're already using TrendMiner to solve real process challenges. The question is how much more value is within reach. Across different implementations, we consistently see the same areas where untapped potential lies:Adoption stays limited to a handful of enthusiasts Value remains anecdotal rather than quantified Best practices live in the heads of individuals Momentum is hard to sustain after initial onboarding Success at one site doesn't spread to others The program isn't clearly connected to company strategyThese are not problems, they are opportunities. And the framework is built to address these... The 5 pillars of successful adoption 1. Vision & ObjectivesA clear vision converts a technology pur
Hello,Our second TrendMiner Success Series Strategy webinar's recording is now available! In this session, we introduced a practical framework built around five pillars that drive successful analytics programs: vision and objectives, people and roles, communication, measuring success, and reinforcement and scaling. For each pillar, we shared best practices from the most successful TrendMiner customers.Watch the recording: https://vimeo.com/1177390498?share=copy&fl=sv&fe=ci👉 We also created a self assessment tool to help you to understand your current maturity level. By answering 25 questions across 5 key pillars you can get your maturity profile, a visual diamond chart, and tailored recommendations in about 5 minutes. Got questions about this webinar? Let us know in the comments below! 👇
As we approach the end of the year, it is the perfect moment to reflect on some of your company’s successes around data analytics, recognize the ongoing challenges, and define a few meaningful goals for the year ahead.To support you in this planning, consider setting up time with your Customer Success Manager. We’d be happy to help you define meaningful goals and identify areas of TrendMiner that you and your teams could benefit from using at a deeper level. Here are some examples:Update your dashboards - The latest versions of TrendMiner have a lot of new functionalities that will certainly give a new look to your dashboards and can help put more relevant information in front of operators, engineers and managers that closely follow key processes in the plant. Connect to more data sources - With an always expanding data landscape, having access to the right data and the right time can really boost your process troubleshooting capabilities. We’d be happy to talk to you about the possibi
Hi,This session shows how TrendMiner helps engineers at Bayer troubleshoot faster, understand process behaviors better, and make smarter decisions across the plant, all explained through real examples shared by Mazie Foret.One highlight was how TrendMiner helped solve a cooling difference that had confused the team for over 20 years.Bayer’s team also uses TrendMiner for other monitoring tasks like: Meter reliability Energy management Centrifuge overflow generation Emissions reporting A cool fact: One of these monitors was actually set up by Mazie’s intern, which shows how simple and user-friendly TrendMiner really is.Curious to learn more? Check out the full recording!
Hi everyone,In this session, Matthew Brantl ( @Matt) shared insights into how Nestlé Health Science optimizes their production processes using TrendMiner. Here are some of the key highlights he discussed: CIP optimization Detecting fouling in critical heat exchangers Verifying tank load cells Using ContextHub and DashHub for monitoring and visualization Check out the full recording to dive deeper into these use cases👇
Hi everyone,In this session, Bita Fillipi @bitafillipi from BASF shared how they use TrendMiner dashboards to monitor boiler efficiency, optimize fuel usage, and reduce CO₂ emissions.Even small adjustments in boiler operation can lead to significant fuel savings, lower emissions, and costs reductions.Watch the full recording below and see how TrendMiner makes a real impact! 👇
Hi 👋🏻Here you can find Kuraray’s presentation at TrendLab 2025 Americas.In this session, Kyle Tillman shares his perspective on how he uses TrendMiner at Kuraray. He also talks about how TrendMiner can support different roles, including field technicians, board technicians and shift supervisors.The presentation gives a clear view of how TrendMiner fits into daily work and how it helps teams make better, faster decisions.The recording 👇
This article comes from a surging trend we see here at TrendMiner: Successful TrendMiner customers have adopted DashHub and dashboards across different teams and departments. Why? Dashboards bring together the work done by key users in the TrendMiner platform, ranging from root cause analysis to operations monitoring and reporting.The end goal is to utilize the knowledge from process experts, combine it with process data into helicopter views that drive process improvements. Have you adopted DashHub in your daily operations and/or reporting workflow? If so, we’d be happy to hear about it in the comments! If you’re not quite there yet, this overview of previous community posts can help you get started: Create an asset overview dashboard: https://community.trendminer.com/use-cases-46/keep-plant-managers-informed-with-a-unit-overview-dashboard-105 Dashboard building blocks: How many times did X happen in a selected timeframe?: https://community.trendminer.com/use-cases-46/daily-counte
Following up on my last post “High Energy Costs Driving New Use Cases for TrendMiner”, I’m excited to share our latest content updates focused on utility and cleanroom performance optimization. In industrial environments, utilities and facility systems - power, heating/cooling, water, air, and waste management - are the backbone of production and can represent up to 10% of total product costs. Key challenges:⚙️ Maximizing asset reliability and avoiding costly downtime🌱 Optimizing energy use for sustainable production🧼 Preventing fouling and improving maintenance efficiency📊 Reporting on sustainability and emissions performance How TrendMiner helps:🔹 Data-driven energy optimization for more sustainable operations🔹 Predictive insights to prevent unplanned downtime🔹 Continuous monitoring & reporting for compliance and transparency Curious how our customers achieve these results?👉 Explore our new page: “Industrial Analytics for Utilities & Facility Optimization”and discover
Hello everyone! 👋In this TrendLab 2025 Europe presentation, our VP of Customer Success Frederick Motte and Ben Schulze (@Ben) from Bayer share their experience working together on data integration. They explain how they brought additional data sets into TrendMiner and how this collaboration helped create real value.🎬 Watch this session to hear why context data matters, how they approached connectivity and implementation, what worked well, the lessons they learned, and the results and next steps of this journey.
Hello,In this TrendLab 2025 Europe presentation, Ruud Timmermans (@ruudtim) from Nobian describes his journey managing TrendMiner from the IT side.He talked about the balance between upgrades, governance, and user engagement.Ruud’s story is packed with honest and practical lessons that many of you can relate to.🎬 Watch his presentation to hear what worked, what didn’t, and what he’d do differently.
Here’s an inspiring session from TrendLab 2025 Europe 🎬In this presentation, Matthijs Geerse (@MatthijsG) from Huntsman shares how their team uses TrendMiner for process health monitoring, from defining what a “healthy process state” means to creating different dashboards that help operators, engineers, and experts collaborate better.💡 You’ll discover: How Huntsman structured health monitoring across teams Real TrendMiner use cases from their sites How they apply Event Analytics and Parallel Coordinates How their monitoring approach evolved with TrendMiner’s data-driven capabilities 👉 Watch the full presentation here:
Time and again, one of the key benefits TrendMiner users share is the ability to receive alerts via email, text, or simply historize them for later review and easy analysis. But when you're in the field, away from your desk, dealing with an issue, those conventional alerts can be siloed and hard to track as a team. In one of my recent conversations with a group of users, they shared they were sending alerts directly to Microsoft Teams. This is a neat collaborative approach that perfectly aligns with TrendMiner's focus on making collaboration easier and brings your notifications right where your team is. Here are the simple steps you can take to set up this integration: 🛠️ Setting Up TrendMiner Alerts to TeamsSet up a dedicated Teams channel for the project or area of interest. (See here for how to create a channel in Teams.) Obtain the channel email address: Select "More Options" next to the channel's name, and then select "Get email address." Copy the email address. Configure a mon
💡 Did you know you’re already saving money every time you use TrendMiner?When most people think of TrendMiner, they think about the insights and optimisations it enables for specific use cases. But here’s something many overlook: the software itself is already delivering value from day one. 🔎 How?Every search, every analysis, and every dashboard created in TrendMiner saves time compared to traditional methods. Less time spent digging for data = more time focusing on decisions that matter. 📊 Turning time into numbersWe’ve started calculating what this means in real terms: 🖥️ Every TrendMiner session saves you time that would’ve been spent digging through data the old way. On average, that’s about €40 saved per session (based on ~5% of an engineer’s yearly salary). 🛎 Set up a few monitors? That’s another €1,000 saved by reducing alarm costs and staying on top of your variables. 📊 And those dashboards packed with decision-making info? They can be worth up to €3,000 in savings. ✨
The old saying “Change is the only constant” couldn’t be more true for the TrendMiner platform. With every release, TrendMiner introduces new functionality—driven by valuable feedback from our end users. Each release brings enhancements and fresh capabilities, but with progress comes a natural challenge: the knowledge gap. Users may not always be fully aware of the latest features, or how to best apply them for maximum value.Here are three ways organizations can ensure their teams stay current and continue to extract the most value from TrendMiner:Continuous Learning Build a culture of ongoing learning by incorporating regular knowledge sessions into your team’s cadence. Focus each session on one or two features, ensuring that the team not only learns about them but also understands how to apply them in daily work. Feedback and Knowledge Sharing Sessions Your CSM is one of your strongest advisors. Schedule quarterly sessions with them so they can hear direct feedback from end users. T
Already have an account? Login
