I’ve made a new tag from a value since the output was in “TONS”. So I made one that converted 170 TON into 170000 kg. Only the kg’s isn’t showing at the end. It’s just the number. Is there maybe a way where you can add the “kg” at the end of a converted number?
Hi - thank you for your question and posting it in our community!
Unfortunately, displaying the new units of measure is currently not supported in TrendMiner. The units shown in TrendMiner are pulled from the data historian. I will make note of this and add it as a feature request! We have had other similar requests, and our team is working to integrate UoM more consistently in TM.
@vally182 At the moment, I would recommend to add the units in the name and/or description of your formula tag. As Kevin already mentioned, our development team has this on the radar, and the option to add units for formula tags should become available later this year, if all goes well.
Thank you for the feedback. That’s the way I do it right now. Put the output unit in the tag. Hopefully this is something that will be featured in the nearby future...
Reply
