We just received the above question from one of our TrendMiner users and as I figured the answer could be relevant to many of you, I thought I’d add it to the Community, so here we go…
When you click on a tag in the list of active tags, you will see a toggle for Accuracy. By default it is on AUTO, but you can switch it on to set your own preferred accuracy.
If set to 0.001, for example, you will have 3 digits after the comma. 0.00001 will give you 5 digits.
More context on the default behavior and the Accuracy setting can be found in our user guide via this link.
