Changing the Language in TrendMiner: Here’s How
  • Dec 23, 2024 11:30 AM UTC
  • Nov 9, 2026 12:20 PM UTC
  • 0 replies
  • 102 views
Natasha Neese
TrendMiner is a powerful software tool for analyzing process data, and its user-friendliness is enhanced by the ability to customize the interface language. Changing the language is one of the most frequently asked questions from our community, especially when a global team with diverse linguistic needs is collaborating on a project.
How TrendMiner Determines the Language
TrendMiner automatically adopts the language set in your browser. To adjust the language, you’ll need to update your browser settings, as explained below for different browsers.
Supported languages are English, German, French, Spanish, Portuguese and Chinese.
Browser-Specific Considerations:
  • Google Chrome:
    Chrome often uses the preferred language set in the browser settings. To check or modify this:
    • Navigate to Settings > Languages.
    • Add your desired language and set it as default.
    • Restart TrendMiner if the changes are not immediately reflected.
  • Mozilla Firefox:
    Firefox also follows the language preferences defined in the browser. Adjust these settings by:
    • Going to Settings > General > Language.
    • Adding and prioritizing your preferred language.
    • Refresh TrendMiner to ensure the changes take effect.
  • Microsoft Edge:
    Edge relies on system or browser language settings:
    • Open Settings > Languages.
    • Add your preferred language and set it as default.
    • Restart the browser to confirm the changes.
  • Safari (macOS):
    Safari adopts the language settings of your operating system:
    • Change the system language under System Preferences > Language & Region.
    • Reopen TrendMiner to see the updated language interface.
Additional Tip:
  • Clear Cache: If the language does not update as expected, clear your browser’s cache and reload the page.
With these additional browser-specific insights, you can ensure your preferred language works seamlessly in TrendMiner regardless of the browser you use.
Happy TrendMining!
