Mapping calculations on search results to context items
  • Dec 19, 2024 4:26 PM UTC
  • 0 replies
  • 354 views
Kevin
When creating context items via search results, it is often useful to map calculations on your search results to a context field for that context item. Once the calculation is mapped to the context item, the calculation can be displayed as a table column in your context view. This feature can come in handy when you want to display metrics or to report KPIs. We will explore a batch example where we leverage this feature.
Consider a batch process where a variety of product grades are manufactured. For a specific product grade, for example product ALPHA, we would like to know the total feed throughput as well as the max quality during the batch.
For this demonstration, we will be using the TM-BP2-PRODUCT.1, TM-BP2-QUAL.1, and TM-BP2-CW.1 tags.
TrendHub view with PRODUCT, QUALITY, and FLOW tags.
1. Create context items via value-based search
To begin, start a new value-based search to identify periods when product ALPHA is produced.
Create a value-based search for ALPHA batches.
2. Add calculations on search results
Add the two calculations - max quality and integral flow (integral of the flowrate will yield flow throughput).
Add two calculations to search results: max quality and integral flowrate.
3. Create the custom context fields and context item type
Head to ContextHub and select the settings icon located at the bottom left.
Note: If you do not see the settings icon, it is because you do not have the correct permissions. Please contact your TrendMiner admin to resolve this issue.
Create two fields - one for max quality and one for flow throughput.
Create new context field in ContextHub settings. Max Quality field is shown above. Flow Throughput field will also need to be created.
Once the two fields have been created, we can create the custom context item type. In the image below, we name this custom context item type “Alpha Batch” and select the two context fields we just created.
Adding the two new context fields to new custom context item type.
4. Create context items and map calculations
With the custom context item type created, we can now head back to our value-based search. We want to add our search results as context items. To do so, select the more options icon to the right of “Results”. Here we can find a command to add context item. Select the correct component/tag, the “Alpha Batch” type for Type, and toggle on the map calculation for both context fields. Once those have been toggled on, we can select our calculations to map to the respective fields.
Create Alpha Batch context items from search results. Map the calculations to the context fields after Alpha Batch type has been selected.
5. View context items in ContextHub view
After the context items are created, we can view them just like any other context item in ContextHub. Head into ContextHub and select the correct time window to view as well as apply the correct filters. In the screenshot below, the type filter is used to filter by the “Alpha Batch” type. To display the custom context fields in the table, be sure to enable the columns by clicking on the blue settings icon located above the table on the right side.
Display the mapped fields in ContextHub in a table.
We now have a context view that displays every ALPHA batch. Each line item in the table also includes the max quality and flow throughput for each ALPHA batch. You can add additional context fields if there are additional metrics and/or KPIs that you would like to display on the table.
