Optimizing Continuous Processes with Event Analytics: Splitting Data into Manageable Hourly Intervals
  • Jul 9, 2024 12:41 PM UTC
  • 0 replies
  • 184 views
Background:
TrendMiner's "Event Analytics" is typically used for batch processes, but it can also optimize continuous processes. By breaking down the data into manageable hourly intervals, this approach provides detailed monitoring and identifies optimal conditions for enhanced efficiency and productivity.
Steps:
  1. Preparation:
    • Add the most important process parameters.
    • Include the pre-installed TM_day_ tag.
  2. Data Splitting:
    • Use the value-based search feature to segment data.
    • Set the condition to TM_day_ constant.
    • Ensure a minimum duration of 59 minutes.
  3. Adding Calculations:
    • Add calculations on the search result.
    • Example calculations: Average Temperature, Integral Cooling Water, Minimum Pressure.
  4. Event Analytics:
    • Use the 1-hour aggregated data within Event Analytics.
    • Analyze the data using histograms or parallel coordinate plots to visualize and identify optimal process conditions.
Picture 1: This parallel coordinate plot from TrendMiner’s Event Analytics shows the relationship between Average Quality, Flow, Temperature, and Pressure over 1-hour intervals. High quality and high throughput (flow) are achieved with higher temperatures, providing insights into optimal process conditions.
Benefits:
This method enables precise adjustments and improvements in continuous processes by offering clear insights into hourly performance. It facilitates data-driven decision-making and provides valuable insights, ensuring consistent maintenance of optimal conditions.
