Steam table formulas for the Tag Builder
  • Apr 1, 2025 3:10 PM UTC
  • 0 replies
  • 108 views
Wouter Daniels
I just saw a question pop up in the community asking whether TrendMiner has built-in steam equations. While they are not built-in, here’s a way to start using steam equations in TrendMiner...
A while back, I implemented the numeric steam table equations found on https://iapws.org/relguide/IF97-Rev.html into TrendMiner Formula Tags. I am posting those here in the hopes it can help some other users too.
The attached zip file contains txt files for formulas that can be copy-pasted into a Tag Builder formula for steam table calculations.
Formula units are currently in Celsius and bar, so you might need to adjust accordingly. Text search and replace should work to change the input units, for example 'P' -> '(P*1000)' to use tags that are in mbar. To change the output unit you can simply multiply the formula by a constant value.
