TrendMiner version 2024.R1.0 released
  • Mar 29, 2024 8:08 AM UTC
  • 0 replies
  • 63 views
Jef Vanlaer
Community Manager
We are proud to release TrendMiner version 2024.R1.0. This release contains the following new functionality and improvements:
TrendMiner 2024.R1.0 continues to build upon event analytics capabilities.  While previous releases delivered quick navigation to reporting periods and shifts of interest, the latest release returns its focus to ingesting and analyzing event data.
In 2024.R1.0, the new plug ‘n play connector for Eschbach Shiftconnector® enables users of both software to seamlessly access shift and event data in TrendMiner as Context Items and effortlessly transition to timeseries analysis of those events. In addition to data synched from Shiftconnector®, the latest release allows you to explore search results in greater depth and dimension.
The new Event Analytics modal is available to visualize distributions of calculated event data and relationships between them. Bolstering the previously released histogram visualization and refinement, the parallel coordinates plot allows you to visually identify different operating modes and relationships between event variables. The parallel coordinates plot allows you to take more dimensions into account than an X-Y plot. This is fitting for processes that have several manipulated and response variables that are expected to impact one another. Utilize these plots to identify optimal operating ranges and to visually identify anomalies.
Finally, Dashboards and Views configured for monitoring operations will now be more easily used by everyone in the plant with the new Shared Space User. This user role extends the maximum session time for an account used for continuous display of information.  This avoids repetitive sign in and set up of the display. The Shared Space User is ideal for conference rooms, control rooms, and break rooms where there may be different groups of people throughout the day monitoring the same areas or metrics.
For more information, check out the Release Notes.
