Solved
alarm when there is no signal
  • Jul 21, 2025 2:02 PM UTC
  • 2 replies
  • 150 views
I want to get an email notification via the monitoring when a tag has no value (connection lost).
Any idea how to do this?
Best answer by Stijn Agten
Hi,
Thank you for this interesting question. Currently TrendMiner can only trigger notifications based on actual tag data. So it is not possible currently to trigger a monitor from within the application if there is no data.
If the use case is to be alarmed when a data source connection is down, there are API endpoints to test the connection to a data source. These can be used to monitor the connection to data sources using other monitoring tools or via a simple script.
If you would wish to see more in-app support for this use case you can share your idea with our product team as explained here:
View original
Stijn Agten
  • Employee
  • Answer
  • Jul 22, 2025 6:42 AM UTC
Hi,
Jef Vanlaer
Community Manager
  • Community Manager
  • Jul 22, 2025 6:57 AM UTC
​@Groot12 You can find more information on the data source APIs ​@Stijn Agten mentioned here:
