Solved
Automatic context item on monitor
  • Dec 4, 2025 9:09 AM UTC
  • 1 reply
  • 90 views
When I have a value based search I can add the result of the events also to a context item (a calculated item).
On the moment I create a monitor out of this, the events are created, but I can not map it to a context item.
For more information see the attached document.
Best answer by fmotte
Hi Luit,
Automatically filling in the calculation fields for monitors is not possible yet. I would suggest adding your vote to the following idea in the Product Ideas section.
Alternatively, you can automate the calculation using a small extension using the SDK. This was covered during the Solutions training at TrendLab - if you are interested, you can reach out to your CSM.
Kind regards,
Fréderick
View original
1 reply
  • Community Manager
  • Answer
  • Dec 4, 2025 9:15 AM UTC
Hi Luit,
Kind regards,
Fréderick
