Solved
Changing data to a step
  • Nov 20, 2025 7:15 PM UTC
  • 1 reply
  • 144 views
I have data which is coming over as analog, but I need to treat this data as step data in calculations, trends, searches, etc.  Is there a good method to accomplish this, as I am unable to change the data type from the historian?
Best answer by Jef Vanlaer
Hi ​@mark.junkins
If it is not possible to change the data type directly in the historian (which would be recommended if this data point should always be stepped), the method explained in the following community post may help to create a formula tag with a stepped appearance based on your original tag. Let me know if this covers your use case…
If this wouldn’t work for your specific case, the custom calculations functionality (available via the expert license) offers a solution, as explained here:
Kind regards,
Jef
View original
1 reply
Jef Vanlaer
Community Manager
  • Community Manager
  • Answer
  • Nov 21, 2025 8:22 AM UTC
Hi ​@mark.junkins
Kind regards,
Jef
