Solved
Checking for Bad Tag(s) in Formula Builder
  • Aug 15, 2025 12:36 PM UTC
  • 1 reply
  • 87 views
yracette
Polestar
Forum|alt.badge.img+2
I used Formula Builder to create a calculation that is the Max of six (6) temperature tags to derive the peak temperature for monitoring.
Is there a function or method that I can use to filter out tags that are reported with a Bad status by the source data historian system?
As it stands, my peak temperature calculation stopped updating because one of the 6 tags is Bad in the Aspentech IP.21 data source
Best answer by Kevin
Hi Yves! Great question - once data is indexed in TrendMiner, there is no distinction between good vs bad quality data. Unfortunately, TrendMiner does not pull in the data quality parameter from the data historian. A different representation of “bad” data would be a product feature request. I suggest adding this as a Feature Idea in the Community.
Thank you,
Kevin
View original
1 reply
Kevin
  • Employee
  • Answer
  • Aug 18, 2025 1:56 PM UTC
Thank you,
Kevin
