Solved
Color code for context Hub views
  • Nov 25, 2025 2:15 PM UTC
  • 3 replies
  • 150 views
Shams92
Polestar
Forum|alt.badge.img+3
Hey,
we are using conditional coloring of CH views a lot. Is there a way that we can deploy color coding rules by the SDK?
We would like to apply the same rules on multiple values and manual configuration is quite time consuming and quite error prone.
Best
Sören
Best answer by fvandael
Hi Sören
Unfortunately, there is no way to achieve this via script or API either. At the moment, conditional coloring rules can only be configured manually in the UI, and the SDK does not expose any functionality for deploying or automating these rules.
If this is a critical need for your workflow, I’d recommend submitting a feature request through the community.
Kind regards,
Frederik
View original
  • Employee
  • Nov 27, 2025 1:08 PM UTC
Hi Sören,
This is not supported in the sdk at the moment, so there is no way to change the color coding rules by the SDK.
Kind regards
Frederik
Shams92
Polestar
  • Author
  • Polestar
  • Nov 27, 2025 1:32 PM UTC
Any other way to do this by script or API you can think of?
  • Employee
  • Answer
  • Dec 2, 2025 2:29 PM UTC
Hi Sören
Kind regards,
Frederik
