Solved
Discrete data are automatically interpolated
  • Oct 3, 2025 10:55 AM UTC
  • 4 replies
  • 137 views
Discrete data are automatically interpolated, is there a solution to only see the real data and export it?
Best answer by Jef Vanlaer
Based on additional information a support ticket was created for further investigation. We’ll update this topic with the outcome when there is more information.
View original
Jef Vanlaer
Community Manager
  • Community Manager
  • Oct 3, 2025 11:32 AM UTC
Hi ​@SIEBE1
Based on your question, I assume you are referring to interpolation when exporting the data to Excel only, correct? In visualization, discrete tags should appear stepped (if that’s not the case, there might be some configuration missing in the connector setup).
There have been similar requests to extend the export functionality from other customers, see for example this Product Idea on this Community:
If this fits with your use case, please add your vote to the Idea and leave a comment explaining your specific use case; that way, our Product Team can better evaluate the idea and determine if it fits the roadmap.
If you feel that your question is different from the idea above, you can also share a new Product Idea.
Kind regards,
Jef
  • Author
  • Explorer
  • Oct 3, 2025 1:04 PM UTC
It is the case you mentioned, the data is discrete but the visualization of the tag is not stepped.
Jef Vanlaer
Community Manager
  • Community Manager
  • Oct 3, 2025 1:09 PM UTC
​@SIEBE1 I have sent you a private message to request some additional information, so I can look into this a bit deeper.
Jef Vanlaer
Community Manager
  • Community Manager
  • Answer
  • Oct 3, 2025 2:33 PM UTC
