Solved
Export Data to Excel
  • May 21, 2025 9:17 AM UTC
  • 1 reply
  • 157 views
Is it possible to access the expoert of tags in Excel directly via Excel? Instead of going into the Trendminer and exporting a tag view, would it be possible to load the data of different tags directly into Excel via API connection and a PowerQuery in Excel?
Best answer by fvandael
Hi Stefan,
There is an api endpoint for extracting tag data which you can use, we do not have a PowerQuery script for this.
On this page you can find more details about the endpoint: https://developer.trendminer.com/compute-api/#_get_index_data.
You will also need to authenticate and get a token which you can find more information about on this page: https://developer.trendminer.com/compute-api/#_retrieving_an_access_token.
If you have any questions feel free to reach out.
Frederik
View original
1 reply
  • Employee
  • Answer
  • May 21, 2025 9:25 AM UTC
Hi Stefan,
Frederik
