Question
Gauge and Current value tiles following the global time frame
  • Oct 14, 2026 7:06 AM UTC
  • 1 reply
  • 25 views
Hi All,
I am building dashboard in DashHub and I have a question about Gauge and Current value tiles.
When I change the dashboard global time frame (for example CUSTOM 1 Oct 2026 00:00 – 2 Oct 2026 00:00, or YESTERDAY), the TrendHub view tiles follow the selected period, but the Gauge and Current value tiles keep showing the latest value (the timestamp on the tile stays at the current time).
My questions : Is there a setting to make Gauge and Current value tiles follow the dashboard global time frame (e.g. show the value at the end of the selected period, or an aggregate over it)?
If it cannt, what is the recommended workaround in the meantime to show a value for a selected day in a single-value tile?
Thanks,
1 reply
  • Employee
  • Oct 14, 2026 7:46 AM UTC
Hi ​@IDRahmiSa,
The current value tile and gauge tile indeed do not follow the global timeframe they are designed to always show the last known values of tags.
However in order to complete your use cases you can use the trendhub view tile in the statistics mode. The statistics table does follow the global timeframe and has a start and end value in it so you can read the start and end value of the global timeframe of every tag in your view in a single tile.
Kind regards
Frederik
