Question
How to configure a drill down dashboard?
  • Nov 5, 2026 6:56 PM UTC
  • 2 replies
  • 16 views
aregis64
Explorer
I would like to make a Plant level dashboard that drills down into areas, then equipment before getting into Trend views. It would be neat if you could create a DashHub view, then set that dashboard as the drill-down target of a higher level Dashboard, similar to PowerBI Drill downs. Similar to how PowerBI drill down works.
eddieh
  • Employee
  • Nov 6, 2026 4:54 PM UTC
Hi ​@aregis64, you can create a dashboard and insert a drill down link via a text tile with a URL link to another dashboard to create a similar effect. As an example, I have this dashboard below which works as a central one from which I can go to any other and return back to the “Home” dashboard as needed. It all opens in the same browser tab so it gives you that same look and feel that I think you are looking for.
Let us know if you need any help setting this up.
aregis64
Explorer
  • Author
  • Explorer
  • Nov 9, 2026 6:59 PM UTC
Oh, I didn’t realize it was that seamless. Yep, exactly what I was looking for.
Thank you,
Aaron Register
