Solved
If formula that returns text
  • Feb 4, 2026 3:13 PM UTC
  • 3 replies
  • 122 views
Hello,
I want to create an if formula that returns text instead of a number, like this:
if(a=1, “Phase 1”, “Phase 2”)
When I try I get an error message but I’m not sure if it’s because it’s not possible or just the writing nomenclature.
Thanks!
Best answer by Natasha Neese
Hello ​@esfarresgu,
Great question! Unfortunately, TrendMiner formulas work exclusively with numerical values and don't support text strings as return values. That's why you're getting an error with your formula.
The workaround:
Use numerical codes instead of text to represent your phases:
if(a=1, 1, 2)
For visualization and interpretation:
  • Display the numerical values (1, 2, 3, etc.) in your TrendMiner charts
  • Create a legend or documentation explaining your codes (e.g., 1 = Phase 1, 2 = Phase 2) → In the formula description or as a text tile on a dashboard
Alternative approach:
  • Use TrendMiner's context items to track and label different operational phases
Hope this helps! Let me know if you have any other questions.
Best regards,
Natasha
View original
Natasha Neese
Hello ​@esfarresgu,
The workaround:
if(a=1, 1, 2)
Best regards,
Natasha
  • Author
  • Explorer
  • Feb 4, 2026 3:40 PM UTC
Hello ​@Natasha Neese,
I see... thanks for the answer!
I’ll try with one of the workarounds for now but I think this would be a feature that would be good to develop at some point.
It would help to be able to bring more clarity and a more direct workflow in situations that you want to communicate information to the operators refering to a digital tag such as a sequence.
Thanks again!
Guerau
Natasha Neese
If you share it in our Product Ideas, our development team will take another closer look at the issue!
