Maximum of conditions in one research
  • Oct 22, 2026 8:01 AM UTC
  • 1 reply
  • 31 views
Hello everyone,
I'm trying to use more than 10 conditions in a single Value-Based Search, but TrendMiner seems to limit searches to 10 conditions.
Does anyone know if this limit can be increased through a configuration setting, API endpoint, or server-side option?
Any help would be greatly appreciated. Thanks!
1 reply
Jef Vanlaer
Community Manager
  • Community Manager
  • Oct 22, 2026 2:49 PM UTC
Hi ​@nwlarivije
A single Value Based Search is limited to 10 conditions indeed. You can however use filters and/or formula tags to iteratively combine more conditions.
To get an idea of how to do this, you can check options B and C in the following community post (the topic is different, but the solution is very similar):
I hope this helps. Feel free to reply if this doesn’t fully cover you case, so we can look into other solutions if needed.
Kind regards,
Jef
