Solved
Monitor using Value-Based Search with Context Fields
  • Aug 1, 2025 4:32 PM UTC
  • 2 replies
  • 131 views
yracette
Polestar
Forum|alt.badge.img+2
I configured a value-based search and added calculations to the search.
I created context items based on the search results and assigned a context type with associated context fields mapping to the value-based search calculations.
Question is: if I configure a monitor using that value-based search and get the monitor to create context items with this specific context type , I see the context fields being listed with optional drop-down boxes. What do I do with these? Will the context item automatically fill-in the results of the calculations to the context fields?
Best answer by fmotte
Hi ​@yracette,
Thanks for the question - adding these dynamic calculations to the monitor results is part of our roadmap. You can upvote the same idea in the Ideas section here:
Kind regards,
Fréderick
View original
  • Community Manager
  • Answer
  • Aug 5, 2025 7:45 AM UTC
Hi ​@yracette,
Kind regards,
Fréderick
yracette
Polestar
  • Author
  • Apr 1, 2026 7:11 PM UTC
Further question on this topic. Again, I have configured several context fields tied to a context type.
I initially uses a value-based search to find past events , added calculations to the search and selected events from the search results to create context items at which time, I mapped the fields.. So at that time, all my context views with fields are filled-in.
Second, I created a monitor tied to my value-based search that creates a context item when the event is detected. This has successfully run for a while.
Because monitors do not yet automatically populate context fields, I now have context items on my selected component and empty field values.
I understand that I could use Python code to populate the fields (per what was covered in Trend Lab 2025), but if I wished to fill-in the missing fields manually what would I need to do? I am guessing:
  • Locate the last fully filled context item with all fields populated
  • Open my saved values-based search with calculations
  • Set the context chart time range from slightly after the last fully-filled event
  • Execute the search
  • Create context items which I believe will create duplicate context items for my component/tag
  • Manually delete the incomplete context items (without data field values)
Am I correct or is there a better way?
Thank you.
Yves
