Solved
Notebooks-embedded DashHub tiles
  • Dec 15, 2025 3:15 PM UTC
  • 1 reply
  • 143 views
garrettmoran
Navigator
Forum|alt.badge.img+1
Regarding embedding a Notebooks output into a DashHub tile via the “Pipeline” feature as an Expert license holder, I am wondering what the limit specs are for bridging the Notebooks/DashHub environments.
I was testing out the Pipeline feature to embed a visual output, specifically a plotly chart, from my Notebooks script into a tile in DashHub. I pulled in a saved View with two tags, converted them to a dataframe on a one-minute granularity, so about half a million data points (they only have data for 2025), and I am able to succesfully plot these tags in a Notebooks output. However, when I publish the notebook to a Pipeline and configure a “Notebook output” tile in DashHub, it loads for ~10s then fails with the error message: “The notebook pipeline is too big to be run by a kernel and cannot be loaded.”
In my Notebook script, for reference, the View loads into the dataframe in about ~120s, which doesn’t seem overly ambitious, so I am wondering at what point the dataframe is too large for the DashHub tile to handle.
Instead of stress-testing the feature myself, I am wondering if there are hard limits on record for the Notebooks output tile in DashHub. Some questions I would have are the following:
  • What is the maximum number of datapoints or maximum time allowed for loading a View in a DashHub Notebooks output tile kernel?
  • About how many Views/tags could a Notebooks output tile handle in DashHub?
If the limits of this feature are known, it would be helpful to know or at least figure this out as we evaluate more use cases for our users. Thanks
Best answer by Wouter Daniels
Hi Garrett,
By default, a Notebook gets assigned a kernel with 1GB RAM, while for a pipeline kernel this is only 256MB, which explains why you are running into issues specifically for the pipeline, but not the notebook.
I can recreate the error message for large dataframes, but I have a harder time figuring out why they are happening, as the dataframe itself should not come close to the 256MB limit.
The issue seems to come from the embedded Python SDK itself. In fact, I can load 500k-row dataframes into pipelines just fine using direct requests. That would also be the workaround I would suggest for now. We are working on an improved Python SDK that should solve issues like this.
You can find a function here that you can copy-paste to load data directly for a given timespan for given tags: https://github.com/TrendMinerCS/mlhub-notebooks/blob/main/Fetching%20data%20examples/get_interpolated_data.ipynb
This should be more performant, and should provide a workaround for the issue you are facing while we work to improve our SDK.
If this doesn't work for you, please let us know!
Wouter
View original
1 reply
Wouter Daniels
Hi Garrett,
Wouter
