Question
return 'no value' in conditional statement
  • Jul 6, 2026 5:45 PM UTC
  • 1 reply
  • 73 views
I am using a conditional statement to calculate the U-value of heat exchanger. If conditions are not met, I would like to return a nan rather than 0. How can I do this?
if(
    and((Q_warm < 13), (Q_warm > 11)),
    (Q/(3.64*LMTD)),
    0)
1 reply
Wouter Daniels
There is no direct nan available, but you can take the square root of a negative number to the same effect. The resulting formula tag will be interpolated over the period with nan values.
if(
(Q/(3.64*LMTD)),
sqrt(-1)
If you want to see actual gaps, a workaround would be to return 'infinite' values, though any calculations/aggregations done on the tag will also show the value to be infinite for those periods.
if(
(Q/(3.64*LMTD)),
1e99
