Solved
Server Storage Requirements
  • Sep 5, 2025 7:44 PM UTC
  • 1 reply
  • 87 views
EdwardB
Compass
Forum|alt.badge.img+1
Good day, TrendMiner hive.
Our IT department has approached me about optimizing our on-prem Azure storage allocation. It appears that our current setup may be over-provisioned for our actual usage.
According to the online documentation for 2025.R2, the minimum storage requirements are listed as:
SSD, 200GB + 300GB, 250MB/s.
However, our current usage is significantly lower:
  • OS: 21GB used out of 511GB provisioned
  • Storage: 109GB used out of 600GB provisioned
Given this, IT is considering reducing the allocation to something more aligned with our needs—perhaps 64GB for OS and 200GB for Storage.
Would such a configuration be sufficient for running and upgrading without issues?
Any insights or recommendations about adjusted the storage footprint would be greatly appreciated.
Thanks in advance!
— Edward Burch
Best answer by Stijn Agten
Hi Edward,
TrendMiner requires 2 volumes: a root volume (/) and a data volume (/mnt/data).
Minimal requirement for the root volume (the OS disk) is 10GB, so it looks indeed like your root volume is over-provisioned.
Minimal requirement for the data volume is 200GB+300GB. The reason we note it down as 200GB+300GB is because our virtual appliance deployment only recognizes 200GB initially and the disk needs to be extended with an extra 300GB after initial deployment. This only applies for our virtual deployment option. Single node deployments can provision a 500GB disk from the start.
Since you use only 109GB of the data storage you could consider downscaling it but please keep in mind the required disk space will keep increasing as time continues and more tags are used. So if you reduce it now you will likely need to extend it again later on.
How much disk space you need per tag per year can be calculated more or less as explained on this page: https://documentation.trendminer.com/en/diagnostics-134908.html
Also keep in mind that some of the free disk space on the data volume is required for successful upgrades: it is only used during an upgrade and freed up again after the upgrade. If you do not have sufficient free disk space upgrades might start failing.
Now, the hard part is that it is not so easy to scale down the disk space.
In case you want to scale down the disk size we would strongly recommend setting up a new server and use the remote backup-restore functionality to transfer the TrendMiner data.
TLDR: 64GB for OS would still be over-provisioned (10GB is enough) but 200GB for storage is on the low side taking into account future increase in storage space and would not be recommended (nor supported in case you run into issues).
View original
1 reply
Stijn Agten
  • Employee
  • Answer
  • Sep 8, 2025 12:37 PM UTC
Hi Edward,
