Solved
This machine learning model can't be saved because it exceeds the maximum number of allowed levels (2) in a machine learning model
  • Jan 14, 2026 8:51 AM UTC
  • 2 replies
  • 145 views
Anyone has faced this problem from mapping the tags to the PMML Model.
The tag that be calculated from the Aggregation after that using in formular tags.
Best answer by Jef Vanlaer
Hi ​@Thanawath.Ruangsamuth
TrendMiner supports two-levels deep of inputs when creating tags in the Tag Builder. This means that any created tag that does not use any underlying calculated tag can be used as input. More levels of "nesting" are not supported. This level of nesting is conceptually shown in the image on the link below.
https://userguide.trendminer.com/en/tag-builder--overview.html#UUID-a4021544-0d9d-5802-2882-96dddd18100c_section-idm4553876347542433914627032423
This limitation exists for performance reasons. Our R&D team is actively looking into solutions to lift this limitation in a future release.
Kind regards,
Jef
View original
Jef Vanlaer
Community Manager
  • Community Manager
  • Answer
  • Jan 14, 2026 9:00 AM UTC
Kind regards,
Jef
Thank for the answer, it’s clear for me now.
