Solved
TrendHub - Line Style and Control Limits
  • May 12, 2026 12:31 PM UTC
  • 1 reply
  • 68 views
I was adding upper/lower control limits to a TrendHub view. The only way we knew how was to go to the 'Formula' tab and create a new tag that is a number (i.e. 45 to indicate the maximum). A couple questions:
  • Is there a better way to do this?
  • Is there a way to modify the Upper/Lower Control limit to be dotted/dashed line to distinguish itself from the other 'real' tags?
Best answer by Jef Vanlaer
Thanks for reaching out, ​@u22333
This is a question we have heard from other TrendMiner users as well. Your solution to create a formula tag via the Tag Builder currently is the easiest way to accomplish this.
However, I have just had confirmation from our Product Team that we are working on the option to add custom trend lines directly to the chart, which will make this a lot easier.
Kind regards,
Jef
View original
1 reply
Jef Vanlaer
Community Manager
  • Community Manager
  • Answer
  • May 12, 2026 12:58 PM UTC
Kind regards,
Jef
