Question
Using Tag Values in Automated Emails
  • Nov 4, 2026 3:05 AM UTC
  • 1 reply
  • 26 views
Hi everyone,
I am working on a project that sends emails automatically. Sending the email is not an issue, but I cannot find a way to retrieve the actual value of a TrendMiner tag.
I would like to use the tag value in the email body instead of sending only a dashboard link.
Is there a supported way to get the current or historical value of a tag from TrendMiner?
Any advice would be appreciated.
Thank you.
1 reply
Wouter Daniels
You can use the REST APIs for data retrieval directly to get historic and current tag values. Of course will need to authenticate to TrendMiner first, for which you will need an admin-generated client user, which should be given access to the corresponding datasource.
If you happen to be using Python for your project, you may want to look into our (still experimental) Python SDK for TrendMiner. It currently only supports getting historic values, but retrieving live values should be added soon.
Let us know if you are having any issues retrieving the tag values!
