Solved
Value based search for future timestamp
  • Aug 22, 2025 9:14 AM UTC
  • 3 replies
  • 110 views
Dear Team,
We have value based search for tag. We want to do value base search and trigger alarm for future value as well. How it is possible?
Best answer by Natasha Neese
Hi โ€‹@tpatelย ,
ย
thanks for clarifying!
When you perform a value-based search, the data is analyzed for the past up to the moment the search is executed. Using Monitoring, you can then receive notifications whenever the defined conditions (e.g. deviations) occur. These conditions are always based on the criteria of the underlying search.
Future (forecasted) values cannot be included directly in this setup. However, you can always adapt your search criteria, and the corresponding monitor will then trigger based on the updated conditions.
For more details, please see:
๐Ÿ‘‰ User Guide โ€“ Value-based Search
๐Ÿ‘‰ User Guide โ€“ Monitors
ย
Best regards,
Natasha
View original
Natasha Neese
Hi โ€‹@tpatel,
ย
thank you for your question!
The combination of a value-based search and triggering an alarm for future values can be achieved via Monitoring in TrendMiner.
You can take your search criteria (e.g. a value-based search) and configure it as a monitor rule. Once the defined conditions occur in the future, an alert will automatically be triggered.
Examples and further guidance can be found here:
๐Ÿ‘‰ Monitoring Thresholds โ€“ Community Use Case
In the same way, you can also monitor your own search patterns or values and receive notifications.
ย
Best regards,
Natasha
  • Author
  • Navigator
  • Aug 22, 2025 9:25 AM UTC
Sorry,ย I have not communicated correctly. I want to include value based search on future forecasted data for the tags . If any value of tag in forecasted data goes beyond the limit , I want to include itย as a triggerย . What I understand currently, It look up to current timestamp for value based search.ย
Natasha Neese
Hi โ€‹@tpatelย ,
ย
ย
Best regards,
Natasha
