It’s Time to Set Your 2026 Process Manufacturing Resolutions
  • Dec 8, 2025 12:32 AM UTC
  • 1 reply
  • 117 views
eddieh
As we approach the end of the year, it is the perfect moment to reflect on some of your company’s successes around data analytics, recognize the ongoing challenges, and define a few meaningful goals for the year ahead.
To support you in this planning, consider setting up time with your Customer Success Manager. We’d be happy to help you define meaningful goals and identify areas of TrendMiner that you and your teams could benefit from using at a deeper level. Here are some examples:
  1. Update your dashboards - The latest versions of TrendMiner have a lot of new functionalities that will certainly give a new look to your dashboards and can help put more relevant information in front of operators, engineers and managers that closely follow key processes in the plant.
  2. Connect to more data sources - With an always expanding data landscape, having access to the right data and the right time can really boost your process troubleshooting capabilities. We’d be happy to talk to you about the possibilities of connecting TrendMiner to other data sources. Think about all the information currently sitting in your ERP systems, Laboratory Information Management System (LIMS), Maintenance/Work Order Systems and many others that you are already using on a daily basis.
  3. Add more contextual information with ContextHub - TrendMiner’s context items are versatile and can be used for many different types of use-cases. Encourage engineers to label events within the process data using manually created context items for when process upsets are identified on a weekly basis. Begin with a small use-case and build from there.
1 reply
Jef Vanlaer
Community Manager
  • Community Manager
  • Dec 9, 2025 9:23 AM UTC
Here’s one I would add:
  1. Scale your solutions - Identify dashboards used by individuals that can be valuable for more people, make sure they are shared and embedded in your daily workflows. Valuable monitors on one piece of equipment, one production line or one plant? Look into rolling them out to similar assets, lines and plants. Contact the TrendMiner team if you need guidance on how to achieve this at scale!
