Solved
Relative time in MLHub?
  • October 29, 2024
  • 2 replies
  • 154 views
brahmneufeld
Compass
Hi team,
I’m working through an example based on this Github example: https://github.com/TrendMinerCS/notebooks/blob/main/MLHub/Get%20Interpolated%20Data.ipynb
In the 4th notebook module there is this snippet of code:
start = "2022-04-17T07:00:02.000Z"end = "2022-04-19T07:10:02.000Z"
How could this be changed to relative time, e.g. start=”-7d” and end=”*” (to use PI’s time notation)?
Best answer by Kevin
Hi there - great question!
You can use the below code:
# Import datetime
from datetime import datetime
from datetime import timedelta
# 7-day pull
# Start and end timestamps to pull timeseries data; format yyyy-MM-ddTHH:mm:ss.000Z
start = datetime.now() - timedelta(days=7)
start = start.strftime("%Y-%m-%dT%H:%M:%S.000Z")
end = datetime.now()
end = end.strftime("%Y-%m-%dT%H:%M:%S.000Z")
Hope this helps!
KL
Kevin
  • Employee
  • Answer
  • October 29, 2024
# Import datetime
# 7-day pull
Hope this helps!
KL
brahmneufeld
Compass
  • Author
  • Compass
  • October 29, 2024
That worked perfectly. Thanks for the quick reply 🙂
