[Recording] What's New in TrendMiner 2026.R1.0?
  • Apr 15, 2026 1:18 PM UTC
  • 2 replies
  • 178 views
Pelinsu
Community Manager
Hello đź‘‹,
We had the 2026.R1.0 release webinar yesterday. Thanks to everyone who joined!
For those who missed it, here are the recording, slides and full release notes:
📽️ Watch the recording
📊 Check out the slides
📄 Full release notes
Share Your Product Ideas with us
Functionality requests can be submitted at https://community.trendminer.com/ideas Requests are reviewed regularly by the product team. Several features in this release originated from Community submissions.
Here is the summary of the webinar:
  • Collapsed Plotting When a filter is active, users can now collapse filtered-out time periods. The remaining data is stitched together and scaled to fill the full chart area. Gap indicators mark where data is non-continuous. This view also applies to Dash Hub tiles.
  • Context Field Configuration Administrators can now configure individual context fields per type with the following options: mark a field as required, set a field to read-only, define field display order, set decimal precision for numeric fields, and add a description to a context type.
  • Index Horizon Management Administrators can now adjust the index data horizon directly in Config Hub. Shortening the horizon frees up disk space. An impact report is available before confirming any change. The default horizon for new installations is 3 years.
  • Plant Integration V5 Plant Integration V5 is now production-ready. Key changes: runs as a standalone service (no IIS dependency), single installer, centralized configuration, HTTPS/TLS support, and up to 10x faster data retrieval from on-premise historians. V4 and V5 can run in parallel on the same server using different ports. V4 deprecation begins later in 2026.
  • SMTP Modernization The email configuration interface has been updated. Supported options include: TLS/SSL encryption, username/password authentication, and a built-in connection test. Compatible with Microsoft 365, Google Workspace, and Amazon SES. Existing configurations are migrated automatically on upgrade.
Deprecations — Action Required Before 2026.R3
The following connectors and features will be fully removed in 2026 R3:
  • Canary 2023 → upgrade to Canary 2024 or 2025
  • Honeywell PHD 4.10 → upgrade to a supported PHD version
  • Prophecy 7 and 8.1 → upgrade to a supported version
  • AVEVA PI AF SDK 2010 and 2017 → upgrade to a supported SDK version
  • MLM tags → migrate workflows to Databricks or Snowflake via JDBC
  • Legacy Python kernel in ML Hub → switch to the current kernel before 2026 R2
Upcoming Events
  • AVEVA World 2026 — Milan, Italy | May 19–21
  • TrendLab 2026 Europe — Eindhoven, Netherlands | September 23–24
  • TrendLab 2026 North America — Houston, TX | October 7–8
Forum|alt.badge.img+2
How does the Collapsed Plotting function work?
Natasha Neese
Hello ​@Jan Maasland,
Thank you for your question! The collapsed filters feature was introduced in TrendMiner 2026.R1.0 and hides filtered-out periods in your focus chart, scaling the remaining data to fill the entire view. This makes it much easier to spot patterns without visual interruptions. At the locations where data has been hidden, small collapsed indicators (parallel lines) appear so you always know where filters are applied.
Enabling collapsed filters can be done in two ways:
  • Click on any filter indicator on the focus chart and select "Collapse all" / "Expand all" from the popup menu.
  • Enable/disable the "Collapsed filters" option in the focus chart settings (gear icon at the top right).
Note that this mode works on the base layer only, and is always disabled when starting a new session or view.
👉 User Guide – Focus Chart (Collapsed Filters)
Best regards,
Natasha
Â
