Valve opening counter
  • Aug 5, 2024 9:26 AM UTC
  • 4 replies
  • 378 views
Background
This use case shows how to create a dashboard that shows an overview of the number of valve openings and the current valve state. In the past this used to be a non-automated procedure, requiring a lot of manual work to count the amount The objective of this dashboard is to streamline and automate the monitoring of valve operations, reducing manual effort and enhancing real-time visibility.
Example of a valve opening tag
Solution
The solution includes the following steps:
  1. Value based search: Create a value based search to identify all the valve opening events you want to display on your dashboard. Save this search for later use.
  2. Contextualisation of Events: Select “Add as Context Item” for the identified events.
  3. Fill in the context item details such as Component (valve opening tag), Type (High Flow), and Description (Valve open).
  4. Monitor Setup: Go to the “Monitoring” tab and enable a new monitor. Use the saved valve opening search and set it to create a context item for each event. Attach the context item to the valve opening tag and save the monitor.
  5. ContextHub View Creation: Open ContextHub and create a new view. Add filters, such as Component = valve opening tag, and set the timeframe (e.g., last 1 day) with live mode enabled. Save the ContextHub view.
  6. Dashboard Integration: Open or create a new dashboard in DashHub. Add a new tile linked to the saved ContextHub view, which counts the number of valve openings per shift. Additionally, a TrendHub view or other forms of the ContextHub view can be added for extra overview.
Results and Value:
The implementation of this valve opening counter dashboard yields several notable results and delivers significant value:
  • Significant time savings: By automatically counting the valve openings a lot of manual work is eliminated, thus resulting in a significant time saving.
  • Enhanced visibility: Now there is an automated and reliable method for tracking valve operations, easily accessible through a centralized dashboard.
  • Improved decision-making: Real-time data on valve openings supports more informed decision-making, optimising the production process.
Thanks for sharing ​@fvandael . It would be beneficial, if one could monitor the number of openings and even save the number of openings as an extra tag. Hopfeully such a feature gets implemented soon
Jef Vanlaer
Community Manager
  • Community Manager
  • Nov 18, 2024 1:42 PM UTC
Hi ​@Emil Barothi
That would indeed make it even more powerful. Our custom calculations functionality already provides a flexible way to create new tags based on searches and/or context items, for example. While out-of-the-box functionality would be really nice of course, this might be a path to look into if this is of interest to you.
Is it possible to have an email alert based on the count displayed in DashHub? We have a certain piece of equipment where I would like an email sent to me when the system over-pressurizes 5x or more in a week so that I don’t get an email for each individual incident in case they are “one-offs”.
  • Author
  • Employee
  • Jun 27, 2025 7:15 AM UTC
Hi ​@benjamindavis ,
The only way to achieve this in TrendMiner is by creating a counter tag using the Custom Calculations feature. You can find some examples of what’s possible with this feature here. Once you’ve created the counter tag, you can set up a regular monitor on it using a value-based search, as described in the use case.
Please note that Custom Calculations are only accessible with an Expert license. If you don’t see this option in the Tag Builder menu, it means you currently don’t have access. You can always reach out to your project manager to check if your organization has any Expert licenses available.
If you’d like to see this become standard functionality in TrendMiner, you’re always welcome to submit a product idea in the community here.
Hope this helps!
