Solved
Predictive monitoring in TrendMiner
  • Jun 14, 2026 9:05 PM UTC
  • 1 reply
  • 146 views
I am trying to understand predictive monitoring concepts in TrendMiner using a cooking process as an example.
Suppose historical data shows that longer cooking cycles are often preceded by slower temperature rise rates, lower steam pressure, or abnormal valve behavior.
What TrendMiner features would you recommend for detecting these conditions early and warning operators before the cooking cycle exceeds its normal duration?
I am particularly interested in understanding the progression from trend analysis and Value Based Search toward predictive monitoring and would appreciate examples of how others have implemented this in process manufacturing.
Best answer by fvandael
Hi ​@TIM,
Worth being precise here, because "predictive monitoring" in TrendMiner isn't one feature; there are three different mechanisms, and the strongest setup combines them. None of them is a trained ML forecast they're precursor detection and a linear soft sensor, but for "warn before a cooking cycle overruns" that's exactly what you want.
Route 1: Validate the precursor first: Diagnose → Cross-correlations. Before you alert on anything, confirm the early signals actually lead cycle duration. Cross-correlation recommends upstream parameters that correlate with your target and detects the time shift — up to 24 hours, split into 100 equidistant intervals — so it tells you not just that slow temp-rise predicts a long cycle, but by how many minutes it leads. This is offline root-cause work, not the alert itself, and the usual caveats apply (correlation ≠ causation; very short windows can score spuriously high). Use it to pick which precursor to trust and to set your thresholds.
Route 2: The real-time early warning (the one I'd build): VBS on the early indicator → Monitor. Scope a search to the early part of the cycle and alert on the precursor there e.g. within the first N minutes of a cooking cycle, temp-rise-rate below X and/or steam pressure below Y. Promote it to a Monitor and it fires within ~2 minutes of the precursor, before the cycle finishes (setting up a monitor). Two practical notes: there's no native "only look at the early window" switch, so you compose it a cycle-start condition AND the anomaly condition — reusing the cycle-start search from your cycle-identification work. And if you want "any of several precursors" (an OR across different tags), the VBS UI only ANDs conditions, so bake the logic into one flag tag EarlyWarn = if(or(rise_rate < X, steam_p < Y), 1, 0) and search on = 1.
Route 3: Optional soft sensor: the Prediction tag. This is multi-variable linear regression: you give it candidate tags, it ranks them by influence score and builds a formula with an accuracy score (your data as a solid line, the model dotted) (prediction tags). You can point it at early-cycle metrics as candidates to get a single predictive score, but two honest caveats: it's linear-only (3–10 inputs), and the docs don't show a worked cycle-duration example so check the accuracy score before trusting it. For a lightweight "where is this heading / time remaining" estimate, the linear-extrapolation pattern is simpler and often enough.
What I'd do: cross-correlation to confirm and time the precursor → VBS-on-early-indicator → Monitor as the live alert → add the Prediction tag only if you want a single soft-sensor score and the relationship turns out roughly linear. The closest community example to this whole pattern (early indicators + value-based search + monitor + dashboard) is the Catalytic Reactor Monitoring and Prediction Dashboard different process, but the methodology transfers directly.
Kind regards
Frederik
View original
1 reply
  • Employee
  • Answer
  • Jun 18, 2026 11:34 AM UTC
Hi ​@TIM,
Kind regards
Frederik
