Solved
Generate an average graph for each day
  • May 26, 2026 8:42 AM UTC
  • 4 replies
  • 192 views
I want to create a graph which represents a typical day for my process, as there is a pattern in the values during each day. So I would like to average the values at a specific time during the day, for the last 30 days or the last year, and create this average value for each timepoint during the day. How would I go about this? The only way I could find to average values is over a single continuous time window, which is not what I want unless I could average several of these time windows and make each window small enough to result in a clear typical day graph (1 minute or 10 minutes for example).
Best answer by fvandael
Hi ​@Jille,
The approach that works well here is combining a Value-Based Search on the TM_hour time tag with Event Analytics Scatter Plot.
Step 1 — Set up the search
Open a Value-Based Search, set your context bar to the history window you want (-30d or -1y), then add TM_hour_Europe_Brussels (or the timezone variant for your site) with condition Constant and a minimum duration of 2 minutes. This produces one event per contiguous clock hour — 24 events per day, ~720 for 30 days, ~8,760 for a full year.
Step 2 — Add two calculations
  • End value of TM_hour_Europe_Brussels — gives the integer hour (0–23) at the close of each event.
  • Average of the process tag you want to profile or any other calculation available.
Step 3 — Open Event Analytics → Scatter Plot
Switch to the Scatter Plot tab and set:
  • X-axis → End value (TM_hour_Europe_Brussels)
  • Y-axis → Average [your process tag]
Each dot represents one hour-block from one day. The 24 vertical columns show the distribution of your tag at each clock hour — the typical day shape is immediately visible, and the spread of each column tells you where variability is highest.
This workflow is also described in the community here (steps 1–4 of the multivariate insights post map onto exactly this approach):
The TM_hour_* and TM_day_* family of time tags are also described in:
Kind regards
Frederik Vandael
View original
  • Employee
  • Answer
  • May 27, 2026 8:50 AM UTC
Hi ​@Jille,
Kind regards
Frederik Vandael
yracette
Polestar
Forum|alt.badge.img+2
  • May 27, 2026 10:49 AM UTC
There is a lot that cane be done by leveraging the TM_hour* , TM_day*, TM_month*, TM_year* demo tags for sure, and event analytics offers nice visuals around this. I wish we could include an event analytics set of visuals on dashboards directly much like we now can with the statistics tables.
  • Author
  • Explorer
  • May 28, 2026 11:40 AM UTC
Hi ​@Jille,
Kind regards
Frederik Vandael
How would I then go about averaging the values at each hour so I'm left with a single dot for each hour?
  • Employee
  • Jun 1, 2026 7:38 AM UTC
Hi ​@Jille,
If you want to calculate the average value for each hour, you can pick up where we left off in the steps above. Once you've set up your search, use the Export Search Results button to export the data:
Export Search Results – TrendMiner User Guide
From there, you can calculate the averages per hour directly in Excel to get the full overview you need.
Kind regards,
Frederik Vandael
